Geared Motor Question
mrmoomoo
Aug 12, 2012
Could anyone recomend a good geared motor? it has to be as small as possible, be low voltage for battery power(up to 24 volts), be at least 1200 rpm(preferably alot more) and have at least 4.65 lb-in of torque.
GreenGiant
Feb 9, 2012
842
quick google search yielded this 12VDC control, 1-1200RPM, 60in/lb torque
and this 24V, 0-3000RPM, up to 50 in/lbs torque...
The problem that you will run into though is that the more torque you need the more current you need, the second one is rated at 22W thats almost a 1A draw, so you would need a pretty large battery pack to run it for long
