Generac IX1600 portable inverter
Geochurchi
Jul 2, 2021
Good morning, after finally getting the motor to start and run reasonably well, it went to pick up the load, Overload light comes on even though the load is under the specs, after tearing the unit apart to get to the inverter module terminal connection and performing the suggested test procedure which according to the specs. I should be reading 195 Ohms on the suggested test points when in fact I am seeing 189K, is this module junk?
debe
Oct 15, 2011
278
Yes its junk, common fault with inverter modules. And it can happen to any brand generator.
debe
Oct 15, 2011
278
Just un lucky. Return it for another one.
