default
- Jan 1, 1970
- 0
I have a fan I want to use with continuously variable speed. It is a
brush less type (specs on this one say 7-12 volts) should work. And
it does . . . but won't take PWM directly, it wants to see steady
voltage not chopped. I tried frequencies from 20 kHz to 1 kHz
1. Is this typical?
2. Anyone else with experience, of speed control of generic brush
less fans?
I tried my circuit with two other junk box fans and they also ignore
pwm, but like steady voltage for variable speed.
Right now I have my picaxe starting at 50 ms on, and 150 off, (ersatz
pwm) up to steady on, in four ranges - which gives me the variable
cooling I want, but it sounds like it is panting and is moderately
annoying.
Plan B:
I really want to continue using an N channel logic level MOSFET and
don't want to disturb the gizmo that's working and in-service for a
variety of reasons.
Seems to me that since my mosfet is pulling the fan's minus connection
to ground, it should be possible to just turn it into a switching
supply with steady DC output. Hook an inductor to the drain,
freewheel diode to the mosfet drain and Plus, and put the fan (load
minus) to the inductor's other terminal (and electrolytic cap across
the fan).
sort of a switching supply, but upside down and backwards
3. Does it sound feasible, or am I missing something?
1. Is this typical?
less fans?
annoying.
Plan B:
variety of reasons.
the fan).
