Generating pulse wave
Joerg
Slater said:
I have this chip:
http://www.gamesx.com/rgbadd/cxa1645.pdf
As explained on page 2, pin 6 needs a "0.4 to 0.5 Vp-p sine wave or
pulse". Also explained on page 12, paragraph #3. The duty cycle must
be 50%.
For PAL operation, the frequency is 4.433619 MHz. I already have a
crystal of such frequency. How do I interface it to the chip?
I'm trying to build this circuit:
http://www.nexusuk.org/projects/rgb2svid/circuit
With that circuit pin 6 will get a lot more than 0.5Vpp.
But I can't find a 74HCT04 anywhere!
Wow, you must really live in the boonies :)
Anyhow, it's just six inverters in there. You could also use a 74HC04,
or a 74HCT00 or 74HC00 wired up a bit differently. If you can't get
those I suggest to move closer to civilization :)
Slater
Exactly!!
I know where to get a 74HC04. Could you please tell me how to wire it,
in such a way that specifications (0.4 to 0.5 Vp-p) are not exceeded?
A little drawing would be wonderful!
Thank you!
Andrew Holme
Page 2 says "0.4 to 0.5" but note 3 on page 12 says "0.4 to 5.0 Vpp" and
talks about it going outside the GND/Vcc supply rails if the duty cycle is
not 50% (due to the internal 1/2 Vcc biasing and ac coupling) which confirms
the 5.0 Vpp. Also, the 74HCT04 output is 5.0 Vpp. So that 0.5 on page 2 is
a typo.
Joerg
Slater said:
Exactly!!
Must be east of Tromso then :)
You just plop it in, has the same pin configuration. Looking at the
datasheet it appears that the first part on page 2 may not be accurate.
Note 3 on page 12 says, quote "The SC input (Pin 6) can be either a sine
wave or a pulse in the range from 0.4 to 5.0Vp-p". 5Vpp is what will
come out of your 74HC04, or ion reality a few hundred millivolts less
but that's fine. The 74HC04 generates pulses, not sinewaves.
So you shold be fine without attenuation. If you ever need to attenuate
it would be easy: 4.7k resistor from U3 pin 4 to U1 pin 6, then 560ohms
from U1 pin 6 to ground. But I don't think you need to do that here.
Thank you!
You are welcome :)
Slater
How much attenuation will those values give?
Slater
Jan Panteltje said:
I am not sure what you want to do,
but that will NOT convert your PC monitor's RGB out to S-video.
So hopefully it was for something else :)
Yes, it's for converting the RGB signal from a videotape to S-Video
Joerg
It's a simple voltage divider, resulting in roughly a factor of 9.4, so
a 5V signal would become 530mV. Realistically less because logic chips
never do a full swing into any load. But according to page 12 of the
datasheet I don't think you need to do this.
Beste hilsen, Joerg
http://www.analogconsultants.com/
"gmail" domain blocked because of excessive spam.
Use another domain or send PM.
Joerg
Jim said:
Neeerp! For a crystal oscillator you want 74HCU04... note the "U"!
Sure, but tough luck finding one of those in the woods of Norway ;-)
It's not nice and harder on the crystal but a 74HC04 usually works ok
for crystals in the low meggeehoitz range.
Joerg
Huh? What kind of VTR gives out RGB? Is this the SCART connector?
Interesting.
It seems the OP lives in Norway. In Europe many VCRs had (have?) RGB,
via the SCART-Connector. We still have our old European VCR, to be able
to watch some of the classic movie from there. Until a while ago we
could occasionally find a foreign movie at the video rental place but
that went belly-up.
Rich Grise
It's not nice and harder on the crystal but a 74HC04 usually works ok for
Harder on the crystal? Use either a smaller cap, or a bigger resistor. ;-)
Cheers!
Rich
Joerg
Then, eventually it oscillateth no more :)
