"ghost" image on Hitachi LCD projector
Ray Carlsen
Does anyone know how to get into the service menu of a Hitachi CP-X430W? It has
a faint double image, apparently in the red channel, and the optical alignment
is correct. The cyan leading ghost image shows up on all screens including OSD
menus. I've seen similar but correctable ghosting problems in other projectors.
Older Sanyo models like the PLC-9000 and other makes such as Boxlight 9600, Eiki
LC-X1 and Proxima 9310 made by Sanyo were "repairable" by getting into the
service menu and changing one data value. I'd hate to toss this Hitachi for such
a fault if it's repairable in that manner. It's out of warranty and Hitachi
doesn't want to talk to me.
Ray Carlsen
A/V Engineering
University of Washington, Seattle
jakdedert
It has
alignment
including OSD
projectors.
9600, Eiki
for such
Ray Carlsen
A/V Engineering
I've seen something like you describe in NEC LCD projectors. AIRC, the
problem was warpage of the affected LCD panel; repairable (replace the
panel), but not economically.
jak
Ray Carlsen
Hitachi CP-X430W? It has a faint double image, apparently in the red
jak,
Thanks for the feedback. We've had quite a few projectors including NEC
fail with bad panels or filters, but the symptoms were quite different, mostly
consisting of blue blobs sneaking through what should be a dark background or
yellow spots on a white screen. They always seem to under-rate the cooling in
LCD projectors.
The fault with this Hitachi is that the "ghost" image is exactly 12 pixels
wide and shows up ahead of normal vertical lines. A warped panel or dichroic
filter wouldn't do that. If a red-only screen is displayed and the RGB input is
fed color bars at 50% level (you will not see it at 100%), the right side of the
red vertical bar is dark, the width of 12 pixels. The green and blue channels
are OK.
As I mentioned before, we had quite a few Sanyo based projectors with the
same kind of problem. The "cure" for those was to change the data in one memory
location in the service menu. We needed the ear of a knowledgeable tech at
Sanyo, and I got it several years ago... that problem was solved for Sanyos.
Ray
James Sweet
antoni.ubieto said:
Finally I've found the service manual for the Sanyo PLC-SU33. This
isn't any reference to ghosting adjustments.
I've tryed varying all the electric adjustments items refering to the
blue without success to cancelling the blue ghost image.
Have you any idea before trying optical adjusments?
Thank you.
Toni.
If it's ghosting, the problem is probably not anything you can adjust.
Usually it means something has failed.
