Glass Tube Fuse Identification
Tim Griffin
Oct 27, 2015
Hi all;
I have a glass tube fuse with the markings 250V 3/3 1A on it.
Could someone enlighten me as to what the "3/3" designation means?
Many thanks,
Tim
shrtrnd
Jan 15, 2010
3,902
I don't have the information at my fingertips, but it will designate the physical size of the fuse.
There are a lot of different physical packages for fuses, and that is supposed to identify the type you have.
Tim Griffin
Oct 27, 2015
Ah, okay. Is there a way I know whether the fuse is a fast-blow or slow-blow fuse?
Tim
shrtrnd
Jan 15, 2010
3,902
Have you got a manufacturer logo on the fuse? The Littelfuse or Bussmann logo, or whomever made it?
That'll tell you exactly were to look for what the '3/3' denotes.
In simple terms, (that may not always hold true?):
A fast blow fuse is a single element, one, fine-wire element ( in a 1 amp fuse).
A slo-blo fuse will be a wire wrapped around a ceramic element (to take the heat, allowing time for a slower blow), or could be a spring-loaded element with many different appearances, depending on mfgr; or a variety of
other appearances depending on who made it.
