Hello everyone , I just joined here from NB Canada. I just purchased the Micromitter stereo FM transmitter kit based on the following circuit. see url below.
http://electronics-diy.com/schematics/BH1417_fm_transmitter.htm
I had a couple questions if you may,
First, has anyone tried removing the attenuator and if so what range can I reasonbly expect to gain with it removed?
Secondly on another page on diy that comments the BH1417 chip, I read a comment saying the following,
Many thanks for reading my post.
Has anyone tried amplifying this circuit or does anyone know of an amplifying circuit that would work with this kit? I would like to achieve about 500ft of range with this unit. I would appreciate any suggestions.BH1417 chip may also be used a stand alone stereo encoder. The advantage of that is that you have full freedom of using a transmitter & amplifier of your choice. You will still have a pre-emphasis, limiter, stereo encoder and low pass filter in one small package because very few external components are required for these blocks. PIN 5 is MPX output that can be directly connected to an external FM transmitter through a 10uF cap.
