GPS - Module Jupitor 31 - Navman Not getting valid data
rajeesh
Jul 7, 2010
I am using at91rm9200dk board
I am using Jupitor 21 Gps module it is working fine
Then I changed the GPS module to high performance one Jupitor 31 .
Now I am not getting valid data.
Please see the data I am getting from gps via serial port
Any body have the hardware connection of Jupitor 31 please send me
Please help me.
$GPGGA,235949.054,,,,,0,00,,,M,0.0,M,,0000*57
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPRMC,235949.054,V,,,,,,,070707,,*29
$PRWIZCH,00,0,00,0,00,0,00,0,00,0,00,0,00,0,00,0,00,0,00,0,00,0,00,0*4D
$GPGGA,235950.049,,,,,0,00,,,M,0.0,M,,0000*53
$GPGSV,3,1,12,20,00,000,,10,00,000,,31,00,000,,27,00,000,*7C
$GPGSV,3,2,12,19,00,000,,07,00,000,,04,00,000,,24,00,000,*76
$GPGSV,3,3,12,16,00,000,,28,00,000,,26,00,000,,29,00,000,*78
$GPRMC,235950.049,V,,,,,,,070707,,*2D
$GPGGA,235951.045,,,,,0,00,,,M,0.0,M,,0000*5E
$GPRMC,235951.045,V,,,,,,,070707,,*20
$GPGGA,235952.051,,,,,0,00,,,M,0.0,M,,0000*58
$GPRMC,235952.051,V,,,,,,,070707,,*26
$GPGGA,235953.048,,,,,0,00,,,M,0.0,M,,0000*51
$GPRMC,235953.048,V,,,,,,,070707,,*2F
$GPGGA,235954.049,,,,,0,00,,,M,0.0,M,,0000*57
$GPRMC,235954.049,V,,,,,,,070707,,*29
14,486
Hi Rajeesh
I do play with GPS units a little. I mainly use them for a source of an accurate frequency that I can lock a 10MHz oscillator to.
I have dabbled with the NMEA data string from the Jupiter T receiver boards, its not too dificult to decode and display date time location etc on a small LCD screen.
In your case I'm wondering if the data string from the Jupiter 31 is slightly different to the 21 receiver and thats why the code in your MCU isnt recognising what it is seeing.
You may need to do some investigating to see what differences there are between your 2 receivers and alter the code in the AT91xxx to suit
cheers
the data below.... is that from the 21 or the 31 ?? have you compared them both yourself ?
what differences can you see ??
Please help me.
SNIP
14,486
Hi Rajeesh,
no posts from you for a few days..... have you read the data stream from the other GPS unit yet. If so how did the 2 of them compare ?
