GPS NMEA, Failover Circuit upgrade attempt.
Sadlercomfort
Ash
Feb 9, 2013
424
I think the negative pulses will be okay, since no mention of this in the Picaxe data sheet.
I do think a diode is needed for GPS #2 on B.1 Pin to protect the Picaxe.
C.5 Serial In pin already has an internal diode.
HellasTechn
Apr 14, 2013
1,579
Ok. What i dont understand in the above circuit is the purpose of D1 and why is its cathode connected to +5V.
also one minor detail would be that the relay will only need to switch the data pins (+) the return pin (-) will be common for CN1, CN2 and CN3 and transistors will not be needed since current required will only be a few ma.
Sadlercomfort
Ash
Feb 9, 2013
424
The diode will not conduct if the serial input is less than 5V. But if the serial swings higher than 5V the diode will conduct and clamp the voltage to 5V.. protecting the picaxe.
I didn't know the return pin (-) was common :rolleyes: but the transistor is still needed to switch the relay right?
HellasTechn
Apr 14, 2013
1,579
No i dont think so. I will have to check to make sure but i think it will not need more than 50ma.
An 7805 will do the job just fine. there will be no need for that diode.
CDRIVE
May 8, 2012
4,960
On the 14M2 physical Leg 2 (C.5 Serial In) is the Program Download pin. It can be used as a Serial RX pin but with caveats. The Picaxe PDF manuals cover these issues.
For complete descriptions of these commands refer to the PDF Manual 2 (Basic Commands).
hSerIn
SerIn
SerRxd
Chris
HellasTechn
Apr 14, 2013
1,579
In the above picture i forgot to mark pin 5 of the DB9 connectors as GND and the same for com pin of the 7805
CDRIVE
May 8, 2012
4,960
Your LED's Anode-Cathode is reversed and it's also missing a limiting resistor. Also, you can't feed a 5V regulator with 5V input.
Chris
14,487
Chris
yes ... exactly ... just a few problems there ;)
you will need bare minimum of 7V into the reg but preferably 8V +
CDRIVE
May 8, 2012
4,960
Why did you remove the protection diode across the relay coil?
Just a tip when posting schematics:
It's good practice to label components, IE... Rn, Cn, Qn, etc. This way we can more easily reference them in our replies.
Ash, I see you've put considerable time into this topic. My apologies for being very late to the party. Especially since it appears you didn't need any help. ;)
Chris
HellasTechn
Apr 14, 2013
1,579
Afrer reading Picaxe manual 1 i see that they do not use transistors to drive LED's so i assume the new diagram without the transistors should be ok.
What do you think ?
14,487
Here is a new diagram. :)
one last thing ..... a serious omission ... you show lines crossing and others that are "T" joints
you MUST mark those that are actual joint else no one knows where there are or are not joints
eg .....
this is absolutely critical,
cheers
HellasTechn
Apr 14, 2013
1,579
Yes that is correcty but if you take a really close look you will notice small dots at "t" joints.
They should be bigger i know but it is the drawing software i use....
14,487
then you need to add them by hand later
and what about all the crossing wire .... intuition tells me some of them are jointed and some are not
but it is totally unknown by your diagram
you need to sort that out .... it has to be made really obvious
