GPS NMEA, Failover Circuit upgrade attempt.
CDRIVE
May 8, 2012
4,960
I thought VisualGps was freeware. I guess not.
Chris
CDRIVE
May 8, 2012
4,960
Are you sure its not supposed to be T4800_4 instead of N4800_4?
Testing this out wouldn't hurt.. I'm reading other peoples experiences with reading GPS NMEA data using PICAXE and they all use T.
Ash, I haven't done so myself but have you read any GPS NMEA posts on the Picaxe forum? While I like to keep things here at EP there is little doubt that the Picaxe forum will have pertinent data.
Chris
Sadlercomfort
Ash
Feb 9, 2013
424
Chris
Yeah but there's nothing useful, I've noticed some do use a max232 to convert logic levels.
Sadlercomfort
Ash
Feb 9, 2013
424
I wrote this, which is supposed to echo back an NMEA sentence like the following:
$GPGSA,A,3,02,24,25,32,,,,,,,,,2.79,1.62,2.27*0E
main:
SERIN c.4, N4800_4, b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12
SERout b.1, N4800_4, (b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12)
goto main
In simulation it works. In real life it echoes back part of the sentence and the rest in characters i dont understand.
I will post them here later.
If Ashley could write a code that would echo back at least GSA sentence then may be able to figure out what is wrong.
I think SERTXD command needs to be used, to send serial data back through the download cable and to the pc.
I think you need something like this below..
Code:
#picaxe 14m2
#DEFINE INPUT_PIN C.4
main:
    GPS1_Read:
    SERIN INPUT_PIN, N4800_4, ("$GPGSA,"),b0,b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13,b14,b15,b16,b17,b18,b19,b20,b21,b22,b23,b24,b25,b26,b27
    pause 1
    SERTXD(b0,b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13,b14,b15,b16,b17,b18,b19,b20,b21,b22,b23,b24,b25,b26,b27)
    pause 1000
goto main
P.S Sorry for not replying sooner !
HellasTechn
Apr 14, 2013
1,579
No worries.
I only use the serial download cable for downloading the program. then i move the picaxe to the breadboard and use 3 wires going to the computers DB9 connector.
PC pin2 connected to whatever transmit pin on picaxe, PC Pin3 connected to whatever receive pin on Picaxe and last PC pin5 to common ground wire
HellasTechn
Apr 14, 2013
1,579
#picaxe 14m2 #DEFINE INPUT_PIN C.4 main: GPS1_Read: SERIN INPUT_PIN, N4800_4, ("$GPGSA,"),b0,b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13,b14,b15,b16,b17,b18,b19,b20,b21,b22,b23,b24,b25,b26,b27 pause 1 SERTXD(b0,b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13,b14,b15,b16,b17,b18,b19,b20,b21,b22,b23,b24,b25,b26,b27) pause 1000 goto main
Ik i see we use c.4 to receive bu to transmit ? b.0?
HellasTechn
Apr 14, 2013
1,579
I will order a few and see what happens after i ge them.
Though i am not sure how to connect a Max232 with a picaxe but i am sure someone in the forum has done that before and can gude me !
Sadlercomfort
Ash
Feb 9, 2013
424
No worries.
SERTXD is just for transmitting via the download cable my bad. You already made a SEROUT program which is similar to mine below:
Code:
#picaxe 14m2
#DEFINE OUTPUT_PIN B.1
main:
    pause 1
    SEROUT OUTPUT_PIN,N4800_4,(b0,b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13,b14,b15,b16,b17,b18,b19,b20,b21,b22,b23,b24,b25,b26,b27)
    pause 1000
goto main
HellasTechn
Apr 14, 2013
1,579
I dont know why but it didn't work. I got nothing at all at the output.
It does work without the qualifier though and when i try to add the variable b28 after b27 it gives me the
Error: Unknown symbol - b28
Why ?
Here is the code that works :
main:
SERIN c.4, N4800_4, b0,b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13,b14,b15,b16,b17,b18,b19,b20,b21,b22,b23,b24,b25,b26,b27
SEROUT B.5, N4800_4,(b0,b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13,b14,b15,b16,b17,b18,b19,b20,b21,b22,b23,b24,b25,b26,b27)
goto main
I will check the data i get line by line and compare them to the original to see if they are correct. I will post logs here.
CDRIVE
May 8, 2012
4,960
when i try to add the variable b28 after b27 it gives me theError: Unknown symbol - b28 Why ?
Uh, that would be because b28 doesn't exist. M2 parts can provide "b" variables from b0 to b27. You can see this in the Variables Window incorporated in the editor. ;)
Chris
Sadlercomfort
Ash
Feb 9, 2013
424
Perhaps try a different nmea sentence. . To see if the problem is the DOP sentence.
CDRIVE
May 8, 2012
4,960
Read up on the SerIn command in the pdf. I think it will light some bulbs in both of your wonderfully fertile young minds. :)... This IS NOT an insult. ;)
Chris
CDRIVE
May 8, 2012
4,960
Ash, Look in Manual 2 - (Basic Commands). I have a suspicion that the qualifier "$GPGSA," may have to be stored in a variable or constant and then reference the variable or constant. I'm deducing this because I didn't see anything in the SerIn description that even hinted that an ASCII or any other value, IE Numeric, Hex or Binary could be used directly.
I'm also curious about the qualifier's trailing Comma that's enclosed in the quotes. Is the Comma part of the qualifier string? If it isn't it shouldn't be within the quotes.
Chris
EDIT: Oops! I just found a qualifier example in the SerIn description using ASCII directly. Sorry about that.
HellasTechn
Apr 14, 2013
1,579
Ok i have my test resaults.
It looks like that without the qualifier it can receive normally. The only issues in my very short test where with sentences GPGSV and GPGLL which are not sentences of interest for us.
I have run the GPGSV twice and GPGLL 3 times. GPLL came out correctly the very first time and last time also.
First line is what i have sent through termite and second line is what i got back. Second lines length is shorter due to limited number of variables.
  • check.txt
Sadlercomfort
Ash
Feb 9, 2013
424
I have a feeling that we simply need to remove the $ from the qualifier, and we can just look for ("GPGSA") in ASCII. Try this below, executes the same:
Code:
#picaxe 14m2 'Identify the PICAXE being used as an 14M2.
let b11 = 0 '
let b12 = 0
let b13 = 0
let b14 = 0
let b15 = 0
let b16 = 0
let b17 = 0
let b18 = 0
'The variables below have been assigned to labels, so now.. instead of writing b11 i can write GPS1_Data and the program automatically subsitutees b11 where the text GPS1_Data is written.
'This helps making the program readable and simple when lots of variables is used.
#DEFINE GPS1_Data b11
#DEFINE GPS1_Signal b12
#DEFINE GPS2_Data b13
#DEFINE GPS2_Signal b14
#DEFINE GPS1_Error b15
#DEFINE GPS2_Error b16
#DEFINE GPS1_DOP w10
#DEFINE GPS2_DOP w11
#DEFINE Buzzer C.0
#DEFINE Relay B.5
#DEFINE GPS1_SERIN C.4
#DEFINE GPS2_SERIN B.1
#DEFINE GPS1_BAD_DATA C.1
#DEFINE GPS2_BAD_DATA C.2
#DEFINE GPS1_TIMEOUT_LED B.4
#DEFINE GPS2_TIMEOUT_LED B.3
#DEFINE GPS1_TIMEOUT b17
#DEFINE GPS2_TIMEOUT b18
main: 'Start 'main' program.
    GPS1_Read: 'Read GPSA Sentence from GPS1
        SERIN[2000,TIMEOUT1], GPS1_SERIN, N4800_4, ("GPGSA"),b0,b0,b0,b1,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b2,b3,b4,b5
        pause 1 '1us Delay
        w10=b2-48*10+b4-48*10+b5-48 'Convert ASCII to Binary
        pause 1 '1us Delay
        GPS1_TIMEOUT=0 'Reset Timeout
        LOW GPS1_TIMEOUT_LED 'Turns off gps1 timeout LED indicator at pin b.4
    goto GPS1_Scan 'Read bits and quality of signal/data
    GPS2_Read: 'Read GPSA Sentence from GPS1
        SERIN[2000,TIMEOUT2], GPS2_SERIN, N4800_4, ("GPGSA"),b0,b0,b0,b6,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b0,b7,b8,b9,b10
        pause 1 '1us Delay
        w11=b7-48*10+b9-48*10+b10-48 'Convert ASCII to Binary
        pause 1 '1us Delay
        GPS2_TIMEOUT=0 'Reset Timeout
        lOW GPS2_TIMEOUT_LED ' Turns off gps2 timeout LED indicator at pin b.3
    goto GPS2_Scan 'Read bits and quality of signal/data
    TIMEOUT1:
    Let GPS1_TIMEOUT=1
    goto GPS1_Scan
      TIMEOUT2:
    Let GPS2_TIMEOUT=1
    goto GPS2_Scan
    GPS1_Scan:
        if b1=49 then
        Let GPS1_Signal=0 'if b1=1 then the GPS has no signal
        endif
        if b1=50 then
        Let GPS1_Data=0 'if b1=2 then data might be missing or corrupt
        Let GPS1_Signal=0
        endif
        if b1=51 then
        Let GPS1_Signal=1 'if b1=3 we have signal and complete data
        Let GPS1_Data=1 'if b0=44 there is a comma before DOP and thus complete data
        endif
        if b0!=44 then
        Let GPS1_Data=0 'if b0 is not a comma (,) then data might be missing or corrupt
        endif
        'Error variable is held between 0 and 3. If more than 3 sentences are bad
        'the value becomes 3 and the GPS is considered inactive. (Filters anomalies)
        if GPS1_Signal=0 then
            if GPS1_Error<3 then
            inc GPS1_Error
            endif
        endif
        if GPS1_Signal=1 then
            if GPS1_Error>0 then
            dec GPS1_Error
            endif
        endif
        if GPS1_TIMEOUT=1 then
            HIGH GPS1_TIMEOUT_LED ' turns on gps1 timeout led indicator at pinb.4
            Let GPS1_Error=3
        else
            LOW GPS1_TIMEOUT_LED ' turns off gps1 timeout led indicator at pinb.4
        endif
    goto GPS2_Read 'Read GPSA Sentence from GPS2
    GPS2_Scan:
        High relay
        endif
        if b6=49 then
        let GPS2_Signal = 0 'if b6=1 then the GPS has no signal
        endif
        if b6=50 then
        Let GPS2_Data=0 'if b6=2 then data might be missing or corrupt
        Let GPS2_Signal=0
        endif
        if b6=51 then
        Let GPS2_Signal=1 'if b6=3 we have signal and complete data
        Let GPS2_Data=1
        endif
        if b0!=44 then
        endif
        if GPS2_Signal=0 then
            if GPS2_Error<3 then
            inc GPS2_Error
            endif
        endif
        if GPS2_Signal=1 then
            if GPS2_Error>0 then
            dec GPS2_Error
            endif
        endif
        if GPS2_TIMEOUT=1 then
            HIGH GPS2_TIMEOUT_LED ' turns on gps2 timeout led indicator at pinb.4
            Let GPS2_Error=3
        else
            LOW GPS2_TIMEOUT_LED ' turns off gps2 timeout led indicator at pinb.4
        endif
    goto Active_GPS
    Active_GPS:
        if GPS1_Error =3 then
            if GPS2_Error=3 then
            HIGH Buzzer 'No active GPS, sound alarm
            HIGH GPS1_BAD_DATA
            HIGH GPS2_BAD_DATA
            endif
            LOW Buzzer
            HIGH Relay 'Set GPS2 as output
            HIGH GPS1_BAD_DATA
            LOW GPS2_BAD_DATA
            endif
        else
            LOW Buzzer
            LOW Relay 'Set GPS1 as output
            LOW GPS1_BAD_DATA
            HIGH GPS2_BAD_DATA
            endif
            if GPS2_Error<3 then 'During this state DOP determines output if GPS1/2 Data ok
            LOW Buzzer
            LOW GPS1_BAD_DATA
            LOW GPS2_BAD_DATA
                if GPS1_Data=1 AND GPS2_Data=1 then 'Only compare DOP if both GPS data is complete with no errors
                goto Active_DOP
                endif
            endif
        endif
    goto main
    Active_DOP:
        if GPS2_DOP < GPS1_DOP then 'If GPS2_DOP has lower DOP
        endif
        if GPS1_DOP < GPS2_DOP then 'If GPS1_DOP has lower DOP
        endif
        pause 5000
    goto main 'Go to 'main' program.
The comma is always followed by $GPGSA in the sentence and therefore can be used. But we haven't used it in the main program. It was simply something else to try.
