David Lesher
- Jan 1, 1970
- 0
Dave Plowman (News) said:Here, a standard circuit is 120v/20A or 2400 watts [at unity PF...]
Indeed. So one circuit should be adequate for feeding any 'portable'
appliances in a room? Excluding heating etc. Not many domestic audio
systems will need a 2400 watt supply. Not even mine. ;-)
You clearly don't know the folks I do...
32 amp is the standard these days.
Thanks to the EU...
So a local centre tap transformer gives you the 110v from a 220 ish
supply? To me it would make sense to not have both sides of that
transformer output in one room - why present an additional hazard if not
necessary?
The local transformer is on a pole outside, or a pad. The breaker panel
is split; half the loads on each leg. Big loads: stove, water heater,
whole house airconditioning, dryer are fed with 240V.
Why would you want 'three or four' 20 amp circuits in a 'family' room?
Why would anyone drive down the wrong side of the road, or use Whitworth
threads? It's not usual for a large room to have multiple circuits. If we
had a 7500 watt scheme, one would do, I suspect.
