Okay, this is more of a laugh than something serious... I just wanted to make sure my thoughts were correct before I started laughing too hard and making an idiot of myself.... I was reading this post/review of a product (below, italicized) I am considering buying... this is an external hard drive enclosure, and thought to myself... Yes, that does remove the "shock" but it also creates a ground loop.... which could cause other issues down the line, particularly with audio coming out of the computer.
Other Thoughts: Where static electricity discharges occur, enclosure must be connected to computer case by a separate grounding wire. If not, static charge from spark when case is touched will travel to computer through eSATA or USB wire, destroying the chips in the computer's interface
(It happened to me once with another device. Needed to replace motherboard.)
And if this is the case.... why have I NEVER had this problem with any of my other enclosures that are metal, to this day (we're talking quite a few years now)?
Edit:
This external enclosure is using a DC 12V power supply (120VAC to 12VDC adapter).
Keep in mind that one of the lines of USB, along with the shield of the USB cable is grounded to the other side of the connection on the computer side.
Thanks for any and all responses!
Edit:
