Bram Stolk
- Jan 1, 1970
- 0
This Grundig TV set shows the red LED when powered on through its
mainswitch. At a 1Hz rate one can tell that the supply is trying to do
something. Commanding the set thru the REMCO does not work either.
I removed its chassis and tried to diagnose the problem.
With the deflection yoke connector (J5-J6)removed and a 60 watt ballast lamp
connected to the A+ the light comes on for about a second when Prog + on
Front Panel is pressed. (Pressing Prog - does not !)
The H+ 5 Volt is steady and always present.
I have removed and replaced the obvious ? parts: TDA 4605-3, 2 Opto couplers
CN17F1, FET T6006 PC50, checked the Caps and A+ 140 Volt ckts for ESR and
shorts.
Opening the fuse S161026 = disabling the +D, +M, +B voltages turns the light
continuously ON, so I suspected a short/load in that ckt. It all measured OK
showing MegOhms. I reconnected the fuse.
Opening the fuse S161036 = disabling the +E, +F, voltages turns the light
A visual learned that R55014 = 4,7 Ohm at pin 5 of TDA8145 E/W Correction
Ckt was exploded, replacement did not result into normal ops.
Is there anyone who can help me to pinpoint the problem ??
Thanks all
shorts.
Thanks all
