Guitar Pickup Winder
GuyPos
Dec 11, 2017
I want to build a unit to wind guitar pickups. I consider myself pretty handy when it comes to building things and tackling new projects but am not an electronics wiz. I could use a little guidance and will research more upon receiving feedback.
Here are some key points.
Must include a counter that can count up or down and be reset. The unit must also slow down and stop once the desired count is reached. Maximum 1600 rpm, very low load as the wire is extremely thin with very little tension. Forward and reverse. As adjustable speed.
Bonus: as an add on to the original build it should have the ability to automatically traverse the width of the pick up (1") max. It must also speed up and slow down with the winding as the traverse speed should move at the rate of one thread width for each complete rotation.
Bonus 2:. Counter presets for different types of pickups. Eg: #1 6000 winds, #2 6250 winds etc.
Thank you
kellys_eye
Jun 25, 2010
6,512
Stepper motors seem the logical solution.
Get the head mechanism from an old CDROM drive as it has a helical screw movement that would be ideal for creating the left-right movement for layered winding. Another (larger) stepper motor could be used for the main core wind process.
Controlling both via Arduino (or similar) should be easy enough given the profundity of 'sketches' for such purposes.
dorke
Jun 20, 2015
2,342
Welcome to Ep.
You need to see this.Simple and very effective.
Adding a counter is simple, like this
or you can make an optical "fork like " opto- cupler counter.
Or like this
hope that helps ;)
