I am using a MOSFET H-Bridge IC (ZXMHC3F381N) driven by a MAX4427 MOSFET driver IC to control a motor.
Actually I've got two pairs of those ICs to control 2 motors using the same signals from a microcontroller and, for some reason, the ZXMHC3F381N blows up after a while. VDD is 12V and the current consumption of each motor at stall is 1.2A.
The first output of the MAX4427 is connected to the gates of the two mosfets (P&N) of one side of the H-Bridge and the second output is connected to the gates of the other side. I fix one of the MAX4427 inputs to 0V while making PWM (10KHz) at different duty cycles to the other. If motors run freely (no load), the circuit works just fine but after changing speeds and applying some resistance to the wheels, it will blow up.
Does anyone see any design flaws? I didn't add extra flyback diodes but I expected the ones of the Hbridge to work for me.
Many thanks and any help is very much appreciated.
