H96 Pro Plus only show blue light
usyusy
Oct 13, 2023
TV Box H96 Pro Plus only shows blue light when connected to charger (tried a few even dc supply 5v), no powered-on and no display. However DC Supply showed 100mA or 110mA usage. any suggestion or clue from fellows will be appreciated.,.regards
H96 Pro Plus
CZ-S32-V3 (DDR4)
2016-12-15(A15)
Delta Prime
Jul 29, 2020
2,995
Did they answer your question?
Delta Prime
Jul 29, 2020
2,995
The consensus is that the power adapter is either poorly designed or manufactured or a knock off.
You are not answering the questions on other sites but that's okay. There's no visible signs of damage to the board and or components therefore upgrade your power adapter. The information you provided tells me nothing.I recommend that you buy a power adapter 5 volts 2.5 amps. Screenshot_20231016_150113.jpgScreenshot_20231016_150800.jpg
