Hard to find Globe
W
What The
I have a small dash globe (or a group as i want to replace them all at once)
that i'm having trouble locating in the right wattage to properly illuminate
my dials.
They are made by Toshiba, ~6mm diameter capsule, wedge base with a 1A/3watt
power rating.
Its 6mm all the way up, *not* larger (~15mm) around the filament like most
of the globes of a higher wattage i've found. A local globe shop at north
parramatta has got the right size, but only in 1.75W and at maximum
brightness i don't feel they're good enough.
Any hints where i might be able to find something to replace my existing
ones?
(P.S Nissan wants $47 each (!!!!!!) for them, not too keen on that price)
Thanks!
W
What The
Looking closer the diameter may even be as small as 5mm, the batter is dead
in my vernier calipers...
Rheilly Phoull
I would be thinking of hi intensity LED's which would be long lasting
and much cheaper than "genuine" !!
Cheers .............. Rheilly P
Den
once) that i'm having trouble locating in the right wattage to properly
illuminate my dials.
1A/3watt power rating.
ones?
Thanks!
These guys have always been able to help me:
http://www.lampreplacements.com.au/
W
What The
Thanks for the suggestion Rheilly.
The trouble with LED's is their "beam". No matter if theyre and inverted
cone diffused type, there is ALWAYS a hot spot and often they don't
illuminate the needles clearly. I was trying to stay away from an LED
conversion on my dash, to do it right, i'd have to dismantle the cluster.
Rheilly Phoull
Yeah, you're right.
I was thinking of the 'idiot lights; :)
Rheilly P
