Having trouble building circuit?
David Lastname
May 14, 2018
Hello, I'm building a circuit(the circuit diagram is attached) and I'm having trouble replicating it in real life. A picture of my current circuit is also attached. Can anyone give me any tips on what I can troubleshoot?
Thanks!
AnalogKid
Jun 10, 2015
3,051
No.
Is the circuit running too fast? Too slow? Did it burst into flames? Think about it - do you really believe that "I'm having trouble" is actual information?
However, the construction does need help.
Add a ceramic decoupling capacitor across the power and ground pins of each chip. Keep the leads as short as possible and connect as close as possible. Value can be anything from 0.1 uF to 1.0 uF.
Add an electrolytic capacitor across the two power buses, anything from 10 uF and 100 uF.
Reduce the length of all power and ground jumper wires.
ak
Chemelec
Jul 12, 2016
291
Put a Switch between pin 3 of the 555 and pin 1 of the other IC.
Makes Decision, Simpler than Lifting the wire.
kellys_eye
Jun 25, 2010
6,512
The LEDs are 'shorted' - think about how the holes in the breadboard are interconnected!!!!!!
They are all connected to each other in a 'strip' and you've put the two LED wires in the same 'strip' of holes, effectively shorting them together.
KJ6EAD
Aug 13, 2011
1,114
Turn the ICs right side up on the breadboard (pin 1 on the left). I can't look at it now.
Audioguru
Sep 24, 2016
3,656
Making an electronic circuit on a solderless breadboard is a tangled mess of wires all over the place.
Audioguru
Sep 24, 2016
3,656
The sloppy wiring mess caused the circuit not to work properly.
David Lastname
May 14, 2018
No.
ak
Sorry for my lack of information. I have another working circuit to compare to, and it seems that there should be voltage on both sides of the capacitors, when there isn't. Any idea why that might be the case? I flipped them around and replaced them already.
AnalogKid
Jun 10, 2015
3,051
If there are no voltages on either of the 555 capacitors, then the 555 has no power applied to it. Pin 5 should read a constant 1.67 V. The other end of each capacitor is connected to GND, so there will no voltage reading there.
ak
