Jon Slaughter
- Jan 1, 1970
- 0
Ok, I just thought that I do not need to control the high side of an
H-Bridge?
Essentially the high side needs to be on all the time(obviously the opposite
side needs to be off).
i.e., if its
H1 H2
L1 L2
Then H1 is on, H2 and L1 are off, L2 is PWM.
Obviously to reverse its the opposite(H2 on, H1 and L2 off, L1 PWM).
Is this correct and good practice? For some reason I was thinking I should
PWM H1 and L2 so that both would conduct at the same time but this seems to
be redundant because turning off L2 should be good enough?
The problem I'm having is that if I do it discretely then its a lot of
fets(or BJT's and resistors + wasted power) and I can't seem to find a
driver that works with high side Pch(they all seem to want to drive Nch).
Even if it takes a few ms to charge the gate capacitance of H1 and H2 it
shouldn't matter because these only occur at the start and end of powering
the motor(the motor will not be reversed often). So I should be able to
drive them directly from logic which will save a few transistors. The low
side will just be done using cmos.
Is this a good idea or not? If not are there any mosfet drivers that will do
Pch high side instead of Nch? (or is it ok to use the ones that drive Nch
with Pch(I'm afraid it will pull the Pch source to far down(Although its
like +-20V so I guess its not that bad but doesn't leave a lot of room))
Jon
H-Bridge?
i.e., if its
H1 H2
L1 L2
Jon
