Marco Trapanese
- Jan 1, 1970
- 0
Hello
I'm puzzling over my own HD44780 library for Luminary ARM. I ported the
code from a working library I use with AVR.
I see some activity with the oscilloscope and the signals seems ok. The
LCD replies as expected. But I can see nothing on the display.
I remember I should see the pixels on the LCD uninitialized after power
up ii the contrast voltage is good. Actually, I can't see this.
I'm sure the display is working because I removed from another (working)
circuit some time ago.
Do you confirm I should see the pixels when the LCD is powered and not
yet initialized? If so, where should I search the problem? Note I'm
powering the LCD at 3.3V but the datasheet of HD44780 says it's ok.
Thanks!
Marco / iw2nzm
Thanks!
Marco / iw2nzm
