Head scratching fault.
dmmarchy
Jun 7, 2013
Hi I have a Cheap Technika 22" lcd tv.. I have a Passion for fixing things etc and cannot fathom out latest problem.. TV turns on, very dim screen almost black. but you can just make out menu etc. I was told to check for blown caps (ie bulging heads ) these all seem okay. I was then told to change the inverter card. which i did and still the same.. Odd thing is when i hold down display button on the remote the screen appears for a couple of seconds, then goes again until i press display button again.. 2 seconds then off... any pointers or clues would be much appreciated .. I know its only a cheap telly but love tinkering and fixing things .( hate to see waste electrical gear in this throwaway society ) Many thanks.
GreenGiant
Feb 9, 2012
842
its possible its a setting, the Backlight setting to be precise, try increasing this.
Measure the voltages to the inverter board, there may be something faulty there.
dmmarchy
Jun 7, 2013
Many thanks for your replies .. Ive been through all the settings and all set correctly. ( was quite tricky had to keep pressing remote display to see screen then 3 secs before it went off. took me about half a hour ! ) I purchased the inverter board new. off Ebay. Could it be the infra red detector ? If i constantly keep pressing the display button screen stays on. but if i stop 3 secnods later goes back to black screen ? Many thank guys.
14,487
I agree with green giant and sheldon
the chances are its either the inverter board or the CCFL tube that the inverter board drives
I have seen very few CCFL failures, 99% of the time its the inverter board
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
It seems odd that the backlight comes on for a few seconds then turns off, with a new inverter board. I guess it could be a problem with the CCFL tube that causes the inverter to detect a problem and shut down... Have you checked for compromised insulation on the CCFL connections? Run it face down in a dark room and look for arcing or corona on the wiring to the CCFL tubes? Also, check the enable signal from the main board to the inverter and/or force the inverter's enable input active.
Those are just suggesitons. I have little experience with LCD TVs. YMMV. Good luck!
