Hearing Aids
PaPaPeng
There is a discussion in a disabilities support group about the latest
hearing aids having an induction loop and digital circuitry. Is
anyone familair with the technology innovations?
Two questions.
1. In what way will digital be better over analog? After all the
requirement is only to amplify sound, not process it - a case of
simplicity over complexity. Even if an analog hearing aid picks up
everything at a noisy cocktail party for example, the human brain is
still the best mechanism to filter out the extraneous noise.
2. What does the induction coil do in in the hearing aid. My guess is
that it allows an outside oscillator to induce a current in the
hearing aid thereby eliminate the need for an internal battery. Its
like the charger for miniature remote control cars at Radio Shack.
colin
Two questions.
Im not 100% sure but I think the Induction loop is used to broadcast sound
to hearing aid users from say a speaker using a microphone. maybe telephones
too?
As for digital processing I heard this is claimed to allow much larger
volume amplification by dynamicaly altering the response to avoid feedback
noises. Im not sure if the technology even exists to distinguish wanted
noises from unwanted ones.
Colin =^.^=
Joel Kolstad
I know next to nothing about hearing impairments, but I'm fairly certain that
in many cases deafness occurs only over specific frequency range(s). That is,
the hearing loss is not just a "flat line" attenuation, but is a significant
function of frequency. As such, it's much easier to create an "inverse" gain
response with digital techniques that it is with analog.
That's pretty subjective. Radio operators use electronic filters all the time
to improve signal intelligibility, and although the "noise" coming over a
radio has a different distribution than the noise at a cocktail party, it's
not much of a leap to suggest that having the ability to filter a signal in
ways other than those that your brain alone provides is useful.
I'm not certain, but besides providing power to an implanted receiver, I would
venture that it probably also transmits the audio itself.
---Joel Kolstad
Steve
Incorrect. The aid should amplify only those sound frequencies which
the ear is not hearing normally. Deafness is usually not a "linear"
problem, high frequency loss is common. Different patients may cut
off at different frequencies. A modern hearing test involves first
plotting the response of the ear across the whole of the normal audio
spectrum. A modern digital aid is then programmed by computer to
amplify frequencies where the ears respose is abnormally low. It
therefore is customisable for the individual patient. Indeed a
frequency plot and programming is done for each ear, left and right
sides may vary for the same patient. If you amplify all frequencies
equally you will just confuse the picture. My son for example has
severe high frequency loss, but normal low frequency hearing, straight
amplification of everything would not be a good thing in this
situation. Older analogue aids did have a configurable frequency
response curve, but it was not so customisable as with the digital
aids and computer s/w.
Harder not easier though if you are being deafened by loud and
unneccesarily amplified low frequencies which the ear hears normally.
Induction loops are a method of directly coupling audio to the aid,
hence avoiding the listener having potentially confusing background
sounds also amplified. Cinemas for example can transmit sound this
way if so equiped. Also telephones, whatever. The aid has a "T"
switch on it which switches over from normal microphone to loop input.
Steve
Joerg
Hello Colin,
too?
Sometimes both, power transfer and signal transfer.
It does. There are filter algorithms and slopes that are next to
impossible in the analog world. It's tough to say that as an analog guy
but that's the way it is. Depending on the case and severity of hearing
loss such filtering must be quite intense. Also, it is much better
programmable for a custom solution than analog. Some applications such
as cochlear implants would be almost impossible in an analog fashion.
Then there are costly component tolerance issues which are eliminated in
a digital design.
Regards, Joerg
Joerg
Hello Steve,
Is there a standard? This would be good for places like our church. We
have a radio wand system but have to hand out analog wands that just
feature a simple volume control. Plus they break all the time. I've got
one here right now where the potmeter became erratic. Again.
Regards, Joerg
Jim Thompson
Hello Steve,
Regards, Joerg
"Potmeter"?? What are you smoking at that church ?:)
...Jim Thompson
Joerg
Hello Jim,
ROFL!
Ok, yes, we are in California but it doesn't go that far...
It's a drag. Much of that "professional" gear is easily repairable yet
often they won't ship you parts or require to send it in to a 'certified
repair facility', meaning lotsa $$$. We could somehow find that potmeter
but I bet then we'd have to do a minimum buy of a whole crate.
Regards, Joerg
John Fields
Hello Jim,
ROFL!
It's a drag.
In CA, I think that's called a "toke" ;)
If you wanted to install an inductive system, I'll bet John Woodgate
could help you out since ISTR that he has some expertise in that
area.
Where is he, anyway?
Prob'ly got tired of the crap on this channel...
Steve
Hello Steve,
Regards, Joerg
Yes there does seem to be a standard, don't know the official name for
it. See the URL below. Places of worship are mentioned in the FAQ
here as a suitable application for the technology. There is a
standard symbol which can be displayed at sites where T loop is
available, which you might recognise, see:
http://www.hearingloop.org/fq_preferred.htm
Steve
Joerg
Hello John,
Hmm, never heard that before. Then again, I didn't grow up in CA. And I
didn't grow anything either :)
area.
IIRC he signed off a while ago because of some job, I think. But it's
been a while.
Regards, Joerg
Joerg
Hello Steve,
Interesting, thanks! I had asked a few of our hearing impaired and none
had ever heard about such a system. Looks like it would be around $2k
for our size church if we do the install as volunteers. That's more than
the existing system but considering the convenience it would make sense.
As long as I can find out whether the majority has T-Loop enabled
hearing aids.
Regards, Joerg
martin griffith
area.
dunno, miss his wit, He's one of the good guys here, along with Win
and Jim (ooops)
martin
Spehro Pefhany
Hello John,
been a while.
I have seen his cross-posts from sci.lang.translation recently, so it
wasn't entirely work-related...
Best regards,
Spehro Pefhany
Jim Thompson
Best regards,
Spehro Pefhany
Well! There certainly hasn't been any requests for serious circuit
design help here in a very long time, so I guess I'll have to just
keep picking on leftist weenies :-(
...Jim Thompson
Joel Kolstad
We're hoping you're going to start writing that book of yours, Jim. :)
John Fields
and Jim (ooops)
So what am I, chopped liver?
Hundreds (maybe thousands) of _free_ designs which work, schematics
which are easy to read and build from and, since I don't blow my own
horn too often, anonymity, more or less.
Lucky me, I get to die as an unknown...
Jim Thompson
Keep me loaded up with "exercises" and I'll start writing. Writing,
by itself, is terribly boring... after all it's an "I did that
already" task.
Reminds me, my wife is very active in charities and Girl Scouts.
Nearly 30 years ago I had a sculpted gold pendant made for her....
(o)
I
DID
THAT
ALREADY
(Except that "THAT" was properly half-spaced ;-)
...Jim Thompson
Steve
hearing aids.
Regards, Joerg
Seems as if there is more awareness of T-Loop here locally in the UK.
It's common to see the sign in banks for instance, as the teller has
to use a microphone to talk accross the security glazing. All the aids
son Tom has been supplied with have a T setting. Check out a major
player like Siemens if you need more detail on them
Steve
