Heat sink calculation
tedstruk
Jan 7, 2012
476
I have to rework a 409046 leslie control for a gulbransen/CBS organ into a 409347 because of a lack of a 409347, so it will require a resistor, and maybe a jumper or two. The board has SC146M thyristors on it now, and one is blown. The circuit requires SC141D's which I have ordered. It also requires 3 - 330 ohm resistors of which there are only 2 on the 409096 board. With this extra resistance, the new thyristors will require a heat sink, and they are fitted with a pin for mounting.
I remember there was a formula for calculating the size of heatsink when they are required, but I can't remember it. I have some scrap heat sink material, but I don't know if it would be a good idea to just cut some pieces so there is lots of dissipation. can anyone help me here? The thyristors are 6a/400 v, the resistors Rtot is 760 ohms, and the caps are .1 uf, reed relay is -12v, diode 1N4148.
tedstruk
Jan 7, 2012
476
Sorry!! made perfect sense to me!!!
I got 2 different builds to use as guides in the repair manual.
One is a 409347, the other is 870241
BUT...
The board I have is a 409046, so I got a Triple threat!!!!
The board had SC146M transistors on it.
The diagram for the 409347 calls for SC141D's thyristors which I ordered.
This diagram has 4 resistors 3 - 330ohm 1 - 100ohm
The 409046 board I have, has 3 resistors and they are 3 - 100ohm
The third diagram is for a 870241 controller, and it has 3-100ohm and 1-330ohm
They are all close to the same thing ...
I was wondering if maybe the thyristors blew because of not having a heat sink on them...
I found the formula in You tube
TempJunction - TempAmbient / PowerDissipated = JuncAmbient
So where
Pd(PowerDissipation) = Vdrop x I(Amps)
JunctionCase + CaseSink + SinkAmbient = device dissipation eg. 25degrees centigrade to see if you need a sink or not.
Most of your formulae seem incorrect.
There is a resource on heatsinking that may help you.
kellys_eye
Jun 25, 2010
6,512
One is a 409347
meaningless to 99.9% of people - what IS that????
the other is 870241
This diagram has
what diagram? Show it.....
If they needed heatsinks they'd have been fitted with them.
So where
but WHAT'S THE LOAD?
Without schematics this is all guess work.
brevor
Apr 9, 2013
87
I worked on those organs years ago, The triacs dont require heatsinks.
