Heat sinking compounds
zms
Apr 29, 2016
17
I have been searching the net, about this thing, and i have come to know that this thing is basically a kind of filler, which is meant for eliminating invisible air gaps, and hence improving the thermal conductivity between the heat source and the heat sink.
But when i came to hear about this thing for the first time, my very first impression regarding this thing was that it was a kind of substance, which when applied on a small area on a surface of a metal plate(for example), then this thing absorbs all the heat which is conducted via that plate, and the entire heat energy is concentrated on that area over which the compound is applied.
is this true ?
14,480
The proper use is to apply it evenly over the whole of the area of the device that mounts against the heatsink
if it isn't applied evenly, hot spots can occur
evenly, but thin!
The heat sink compound is not an especially good conductor of heat. But it's way better than air. You want the most metal to metal contact with the compound filling up the remaining air gaps.
shrtrnd
Jan 15, 2010
3,903
The 'thing' is called silicon heat sink compound, an example if you want to look it up is the Dow Corning 340.
It's pretty messy to work with and some people don't apply it properly.
There are several types of heat transfer pads on the market now that are cut from thin sheets to the size of each
particular semiconductor case package type. Instead of messing with the thermal heat-sink compound, you can buy pre-cut-to -size thermal heat transfer pads that are solid, flexible even-thickness for your application.
Minder
Apr 24, 2015
3,561
Do not confuse it with Silicone dielectric grease, as some have done, it has the opposite effect!
M.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,985
... it was a kind of substance, which when applied on a small area on a surface of a metal plate(for example), then this thing absorbs all the heat which is conducted via that plate, and the entire heat energy is concentrated on that area over which the compound is applied.
is this true ?
No it is NOT true. Ideally, heat-sink compound would not absorb any heat. Instead it would allow whatever heat is generated by the active device to pass freely through the thin layer of heat-sink compound into the attached heat sink, whereupon the heat is transferred to the environment. In actuality, there will be a temperature drop across the heat-sink film, but there is very little heat absorbed in the film because its heat capacity is small.
