heath/zenith wireless door chime problem
davidbenjamindix
Feb 25, 2010
21
i purchased a heath/zenith wireless doorbell chime kit (model # SL-6147-WH) that runs off of (2) 1.5 volt batteres, which produces 3V through the doorbell. i then detached the speaker, and am trying to use the doorbell to power a 3V DC motor. (range 1.5-3V). the volts running through the wires where the speaker was soldered is about 3.1V. the motor works because i've tested it with 1.5V and 3V. also, when i depress the push button for the doorbell and the motor is connected, i can hear the vibrations of the 'chime' through the motor. the problem is that the motor is not turning when i depress the button. i wondered if maybe the signal being driven to the motor is sound signal only? are there resistors that need to be taken out? or maybe a transistor? im just starting to learn about electricity, so im just completely confused.
Ice Coffee
Feb 21, 2010
4
interesting concept,
1) Sound signals are electricity there is no difference, however it is important to note that sound is AC by nature, and you have bought a DC motor,
2) even if you had bought an AC motor it still probably would not work because the AC motor you purchased might be expecting 50/60 Hz and your sound signals are probably made from a multitude of frequencies ranging from 500 Hz to 4000 Hz
anyway this ebay item exactly fits your requirements for a remote controlled switch
http://cgi.ebay.co.uk/2-Channel-RF-...arts_Vehicles_CarParts_SM?hash=item23057c2f2c
unless it NEEDS to be doorbell shaped in which case you can buy one of these doorbells and replace the feed to the light with your DC motor !
http://cgi.ebay.co.uk/Byron-TX14-Wi...&itu=UCI&otn=3&ps=6&clkid=8100230867376702103
