Help - Ademco Vista10 and Compass downloader
Anyone here familiar with this setup?? I have a Vista10SE rev15 and I can't
get Compass 1.5.8.0 to connect to it. I am using a Hayes Smartmodem 1200,
but when I try to connect direct to the panel using the "telco" option,
communications start, verify CSID seems to work, but when the checking
panel status, it hangs and tells me there has been no commucnications for
30seconds. I could just use my two-line alpha display to program it but I'm
too damn stubborn!!
Any thoughts?
-Will
AnotherAnonymous
can't
I'm
too damn stubborn!!
Any thoughts?
-Will
I had this problem a couple of times, the 1st time was with a vista 10SE
turned out there was just enough noise on the telephone line to stop it,
always seemed to be in the same spot you speak of too and it could barely be
heard with a handset. the 2nd was with a vista 40. no noise on the line,
clear as a bell but when I had the telecom dept. where i work go out with
his butt set and talk to me on that line, there was a severe 'echo', so to
speak. almost like it was a VOIP or some kind of line amplification which
wasn't heard until I talked to the guy. I'm not sure what the problem was
there, the telecom guys ended up deferring it to SBC and in a couple of days
it was back to normal. just a thot, hope this helped.
Noise shouldn't be a problem, I'm hooking my phone cable directly from the
modem to the tip and ring terminal in the panel, then starting comms on the
panel with Installer code + # + 1, then connecting from the software. This
is alluded to in the manual for the Vista 10, so I hope its correct.
-Will
shyju
shyju had written this in response to
http://www.secure-gear.com/alt.secu...sta10-and-Compass-downloader-article9005-.htm
Any one have user name & password for login to ademco site for
downloading Compass.. Please help...
Regards,
Shyju
the
the
This
message
Delivered via http://www.secure-gear.com
The Internet Knowledge Base for the security industry
no-spam access to your favorite newsgroup -
alt.security.alarms - 43309 messages and counting!
