N
[email protected]
- Jan 1, 1970
- 0
I am a novice and would like to build a 120V AC outlet which can be switched
on and off by USB. I'm not sure what all I will need and want to make sure
that I'm not trying to do something much harder than it sounds. My end goal
is to have a single plug where I could plugin a lamp, TV, power strip, etc
and have the power to that device controller by a PC via USB port. Now I've
seen some devices out there like X10-compliant home automation controls and
there has always been a severe limitation in one way or another. I would
love the pulg to be grounded but it doesn't have to be if that is a
complicating factor.
It seems to me that I need a relay which can switch the 120V on/off and then
need a USB controller to control the relay. And I have seen USB controllers
which have serial interfaces on them but then how to get from a pin or two
of a serial port to the relay is where it breaks down in my head. I'm not
sure what I need between the two or if that would even work. I can handle
the software part of it once I get a hardware solution idenfitied.
Can any of you pros offer advice to get me going in the right direction?
Thanks!
Frank
Thanks!
Frank
