Help! Connecting power supply to small load/solenoid
oddabe83
Feb 10, 2007
4
Hi!
I bought this solenoid from an electronics hobby shop.
It consists of just coils of wire, with a metal rod in between, such that when current is passed thru the solenoid, magnetic field is created and the rod "sucks" inwards.
The problem is, the solenoid is connected by a DC supply. As soon as it is connected, even though the rod did suck inwards, the whole circuit shorts itself. The solenoid's resistance is only 3.6ohms. As such, if I put a resistor in series with it, little voltage is passed thru it (it needs at least 6V), and it wun work.
Can anyone kindly draw me a circuit that alleviate such situation? I need 6V to pass across the solenoid, and as little current as possible..
Thanks in advance!
audioguru2
Apr 6, 2004
12,022
Just calculate the required current by using Ohm's Law. I= 6V/3.6 ohms= 1.67A.
oddabe83
Feb 10, 2007
4
Do u mean if i provide the correct amperage, the circuit will not short itself?
Is it true that solenoids in a DC circuit is actually a short circuit?
ante1
Jan 24, 2004
4,136
The solenoid must have no less than the calculated amperage to work as intended and it will grab this current when the correct voltage is available.
No, that
oddabe83
Feb 10, 2007
4
I suspect it might short circuit as the coil is really just wires coiled up into a lump. Are inductors actually solenoids? Inductors actually shorts themselves if connected to a DC supply right?
What would you suggest to prevent the high voltage? Will a diode help?
audioguru2
Apr 6, 2004
12,022
Why do you say the solenoid shorts?
Does it cause a 6V battery or a 6V power supply to get hot?
Does it cause the battery or power supply's voltage to drop?
Is the battery or power supply capable of feeding a 1.67A load?
ante1
Jan 24, 2004
4,136
You know 3.6 Ohms is not a short!
A solenoid is an inductor.
What sort of power source do you use?
Fowkc
Nov 20, 2006
29
A solenoid is not really a "short circuit" in the normal sense of the word.
If you drew out the wires in a solenoid or inductor, the behaviour would be of a normal piece of wire. The coiling up of the wires means that the coil creates a magnetic field inside it. This magnetic field in turn sets up a voltage across the solenoid which will oppose the applied voltage.
The measurement of the resistance of a solenoid (as far as I know), is not a very good indicator of the current it will draw, as the behavior is dependant on that current.
Think about a transformer winding: low resistance, but the behaviour when a voltage is applied is very different from a resistor of the same value.
audioguru2
Apr 6, 2004
12,022
The magnetic field in a solenoid sets up a voltage across it that opposes the applied voltage, during the slow build up of the current. The solenoid is an inductor that builds up current slowly. When the current reaches the max then it is exactly the same as in a resistor with the same resistance as the solenoid.
