Help Flexible Flat Cable Connector
Scott Olson
Nov 9, 2014
Can anyone help me with this connector. I can not figure out how to open it and lock the cable in place. It is from aa Anova Sous Vide circulator.
Thanks in advance for the help
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
This looks like a PCB edge-connector socket with some sort of retention mechanism on the ends. Is the cable attached to a PCB paddle board? Unless there is hardware (latches, whatever) on the mating piece, it does not appear that there is anything on the socket that would allow you to "open it and lock the cable in place."
14,484
Agreed .... unless the little lever has been broken off
NOTE the grey section, the central part is wedge shaped and pushes the cable contacts against the connector contacts as can be seen in the OP's pic
