Help for ELF (extreme low frequency) design
electronicNovice
Jul 26, 2015
11
I wanted to design circuit that outputs extreme low frequency, between 4hz and 10Khz. I want to use microprocessor. I have found some microprocessors that outputs that kind of frequency. The problem is the amplitude of the signal. Has to be around 10-12V. Usually the microprocessor outputs 5V. Any idea how can I go with this design and what microprocessor to use.
14,299
4 Hz ... 10 kHzz can be generated by various means. If you opt for a microcontroller: (almost) any microcontroller will happily generate a signal in this frequency range.
As for amplitude: use an amplifier. Circuits for amplifiers that work well in this frequency range can be found on the internet.
WHONOES
May 20, 2017
1,242
The ubiquitous 555 would do that easily over the voltage range you quote and, it is easy to vary the pulse width if desired.
kellys_eye
Jun 25, 2010
6,512
Just purchase a bog standard audio signal generator.
Most have outputs that go to 15V (or more), range from 0.01Hz to 100kHz and have sine, square and sawtooth waveform outputs.
WHONOES
May 20, 2017
1,242
Perfectly true.
