Help identifying SMD Diode
Leggyownz
Feb 7, 2017
55
I have this diode that is reading both ways. When plugged in it gets hot and starts smoking, I suspect there is another problem within this machine but wanting to attempt to try the diode and a proper power supply first. I haven't had to do much with SMD components at this point and so I haven't had to look up the codes before. I tried looking the one on this diode up but came up empty handed on my search. Hopefully someone knows what I'm doing wrong and can explain it to me for future reference. Thanks in advance
14,487
I assume you are referring to D3 ?? you didn't give that info
what is the reading in each direction ?
what is written on the diode ?
it's possible that Q1 is affecting the reading
the diode will need to be removed for proper testing
and probably the same for Q1
Leggyownz
Feb 7, 2017
55
D3 gives a dead short both ways. Reading through Q1 gives completely different readings thanks to c2 and c3. The dead short only occurs across d3. I can pull it off and test it which isn't a problem but was trying to identify it first on the off chance it falls off the board and gets lost or something damages the top of it (just the rare but absolute pains that could occur)
kellys_eye
Jun 25, 2010
6,512
Indicative of reverse polarity applied to the device - be prepared for more faults!
14,487
so you didn't answer my Q
WHAT is written on it ?
Leggyownz
Feb 7, 2017
55
Sorry, missed that question. So it says "407" on the first line with an emblem of some sort before that and "L Z" on the second line below it. Picture below is my drawing of what it says including the emblem.
I am definitely assuming more faults to come after this.
[Mod Note -- Image resized]
