Help in opening LCD monitor
softdown
Jan 26, 2009
4
How can I open a LCD monitor (model Belinea 101920) ?
After unscrewing all the visible screws, I could remove the "foot" but the case still doesn't open.
On the net, sometimes a case opening key is mentioned. Indeed, there is a hole in the back of the case with a "K" inscription (maybe stands for "key").
Where do I buy such a key ? I tried Google, but without success ?
ccm
Nov 23, 2009
I hope you already fixed your monitor by now.
Anyway, the little K and lock symbol has nothing to do with opening up the back panel. the lock symbol indicates the hole may be used for security. for instance, at a school or library, the hole will be used to pull a wire through it and secure it to a table or lock.
As for opening the monitor, I have not done that before, BUT, I frequently read that after the screws are removed, you just have to carefully pry it open using a flathead screwdriver. Wedge the flathead into the seams.
Look for clips along the seams.
