jackorocko
- Apr 4, 2010
- 1,284
- Joined
- Apr 4, 2010
- Messages
- 1,284
Ok. little background on myself. I am a high school graduate with no formal electronic education. I read books and tutorials etc online. I think I am above the curve when it comes to understanding electronics, but where I struggle at is the design of circuits. I think a lot of this comes from a lack of knowledge of the math behind the design.
So what I want to accomplish is to teach myself effectively how to design circuits.
I was asked if I could make a simple trip laser security alarm that a friend had seen online, here http://www.wonderhowto.com/how-to-home-laser-beam-security-system-251050/
Now, afaik, The way this circuit works is that the laser upon hitting the photocell causes the resistance to decrease enough so that the flow of current is higher threw the photocell to ground. this effectively keeps the 2n3904 in an 'off' state. As soon as the laser is interrupted the resistance threw the photocell now is very high causing the flow of current to the transistor to increase, effectively putting the 2n3904 into a 'on' state. This completes the siren circuit and causes current to flow threw the load across the collector-emitter and to ground.
Now if all I said above is correct and I understand the principle of the circuit, how do I go about figuring out the math? What is important to know about this circuit that I would need to know from the datasheets of the components?
I am under the assumption the transistor works on current, if enough current is applied to the base, the transistor will turn 'on' But, I can not for the life of me figure out the values needed for the resistors. This is where I have major problems. I though I read somewhere that I need to break down the circuit into it's sub-circuits to do the math. I see two sub-circuits in this design, the alarm circuit and the photocell circuit. Does the variable resistor work as a voltage divider in this instance?
So I'll end there for now. I hope someone can help me with some insight, even if it's to post a link to a website where I can read and learn the exact procedure for doing this sort of stuff. I WANT to learn.
Also, isn't there some easy electronic simulation software I can use to design this circuit and tinker with it in simulation? I tried 'solve elec' , but that program seems to be severely lacking or I am just completely incompetent.
