Help me figure out what is going on with my shoplights
Truckdrivingfool
Sep 30, 2012
33
A few years ago I hung 11 cheap shoplights in my shop and life was great. Then in the time span of a month 10 quit working. I figured cheap lights=cheap caps so I tore into one and found a swollen cap to back my theory and ordered some new caps. The first three went smooth, numbers 4, 5, and 6 weren't resurrected after the capectomy so I started looking harder and found a fuse that was blown on all three. Number 7 I checked the fuse first (was good) and proceeded with the cap replacement to bring it back life. Number 8 - Fuse - good, replaced caps, light still no work, recheck fuse - bad. Took it a step further and jumpered across fuse - Instantly popped newly replaced cap.
New caps installed to the same polarity as the old ones (matches the printing on the board too), so I know that its not that. The pcb in the lights have nice wide traces so I didn't cause any kind of solder bridge. I don't see anything else absolutely/obviously wrong or looking fried.
Is it possible they had a bad day at the cap factory and I got a bunch that are somehow absolutely marked and pinned backwards?
What else would cause the fuse to blow by simply replacing the caps?
Truckdrivingfool
Sep 30, 2012
33
Ya but more to my point why would the replacement of the caps suddenly make the fuse go when even the original crappy ones didn't? Plus more over cause the one I sacrificed with the fuse jumper to instantly pop when I plugged it in?
Arouse1973
Adam
Dec 18, 2013
5,178
Can you take some nice pictures of the inside of the lights and to include these capacitors, also the new ones you replaced the faulty ones with.
Adam
14,470
because on that unit there is also another fault
as Adam said ... show pix
Truckdrivingfool
Sep 30, 2012
33
Originals untouched
New installed
Both side by side
If there's anything else I can picture let me know. Also can anyone tell me where I can these? They are smaller than the 5x20mm that I've been able to find. Best I can read they are 2.5A 125v.
Truckdrivingfool
Sep 30, 2012
33
I'll add that out of 10 I've done 8 and I'm 4 and 4 on the successful vs unsuccessful. Two I know for sure the fuse blew on the first power up after replacing the caps.
For the they have another fault answer I ask why didn't the fuse blow in the first place when the new caps didn't go until I bypassed the fuse?
shrtrnd
Jan 15, 2010
3,901
Sounds a lot like davenn and Arouse1973 are right about cheap components being the problem.
As to your trying to ascertain the cause of the fault, two possibilities come to my mind:
1) The bad caps may have weakened other components in the circuit.
2) Are the plugs polarized? I had a problem once where bulbs burned-out too quickly. I traced the problem
to the wiring of the bulb drivers. I had unpolarized plugs, and some of the bulb drivers had the hot lead going
to components that the neutral lead went to in other lights I had in the same mains circuit. Caused damage.
Good luck in figuring this out.
BitHead
Mar 2, 2012
34
Anecdotal words... I've seen those caps blow before on circuits like that and I replaced them with '50V higher' caps and all was well - sort of - there was still some electrical noise on my shop AM radio - so I had a closer look and found a 'snubber circuit' - diode, resistor and cap - with a blown diode. The switching-transistor-transformer section was putting spikes on those original caps - which exceeded their ac current or voltage rating - and that's the reason they failed. They were rated OK for a circuit that did not have another failed part on it. :) So... maybe check the diodes?
Arouse1973
Adam
Dec 18, 2013
5,178
Can you take a picture of the whole PCB looking down on it. Also a whole picture of the bottom side of the PCB, that would be great.
Cheers
Adam
Truckdrivingfool
Sep 30, 2012
33
Sorry it took so long to get back to this, the plugs are polarized, here's pics of both sides.
#9 the fuse was blown right from the start, so here's me saying ok ya told me so. Since i have no more test equipment than a multimeter I may just be happy with saving half the lights and bite the bullet on buying new cheap shoplights to cover the rest.
twister
Feb 12, 2012
172
Usually when acap blows up when you apply power it means the polarity is backwards. I did that once! Very loud!
