Help me in Building a UPS
masterleous
Jul 20, 2004
38
Hello all users,
I need some help in my project of UPS, i found some basic conecpt of UPS on NET, which is basically a 12 volts to 220/120 VAC Inverters, these types of circuits have a big problem with them, when a battery is fully charged, UPS give 220 VAC, after some time when Battery goes to its 50%, than UPS give 180-190 VAC, and when battery goes to it minimum, UPS give less than 160 VAC. So UPS is only efficient when battery is fully charged.
I found some ideas from net of UPS continuously giving 220 VAC till battery goes to 30-40%, but not find any circuit of that type of UPS.
Any circuit idea/schematic..........
masterleous
ante1
Jan 24, 2004
4,136
You have to give some more info of what you are powering from this UPS. A standard SMPS PC PSU will have no problems with the voltage drop, some works from 96 to 275VAC. But it’s perhaps not a PC you like to run from the UPS. It might also be a problem caused by bad choice of battery types or size.
steven2
Jan 19, 2004
1,698
:)what are those large hevey transformers in the ups as i scored one its a smart ups system and  ive now got 2 large transformers i got from a total of 2 ups now
