Help me to understand the MC3359P IC
walid1
Jun 27, 2004
749
Hi
Below I attached the datasheets of the MC3359P IC.
I have a ruined cordless phone (SENAO SN736)
From this phone I’ll get that IC and the related components, and with your help and some modifications, I want to build a FM receiver.
Lets go:
(1) What the meaning of RSSI written at the beginning of the datasheets?
(2) Is this receiver possible?
(3) For the following schematic (from the datasheets) and if I use audioguru’s FM Tx as a Tx, what is the 10.7 MHz i/p connected to pin 18?
Remember that I have all the components in the schematic above from the phone itself.
Thank you a lot.
MC3359P_IC.pdf
  • MC3359P_IC.pdf
Kevin Weddle
Feb 23, 2004
1,620
The 10.7 MHz is the carrier received from the antenna or cable, whichever. I believe the RSSI is a digital I/O of the microcontroller. They are always many I/O's, I think this is a popular one.
walid1
Jun 27, 2004
749
thank u Kevin Weddle for fast reply
Now if audioguru's FM Tx is sending with carrier freq = 100MHz
what stage must be connected to that i/p to receive signals
thank u
audioguru2
Apr 6, 2004
12,026
No Kevin,
Hi Walid,
The IC circuit is only part of a radio. The "front-end" of a super heterodyne radio is missing. The front end is the RF amplifier, local oscillator and RF mixer that converts the RF signal to the 10.7MHz IF (intermediate) frequency that is easier to amplify and filter than the VHF RF signal.
To change the RF frequency, only the local oscillator frequency (and an RF filter if used) needs to be tuned and the tuning of all the IF filters stay at 10.7MHz and 455kHz.
This receiver is "dual conversion" because it has a second local oscillator and RF mixer that has a 455kHz output that is also amplified and filtered.
Learn about how a super heterodyne radio works from articles in Google.
Kevin Weddle
Feb 23, 2004
1,620
I think in most cases, there is no intention to step down the frequency of an FM carrier. AM uses mixers. If you play with the frequency of FM, you might not be able to recover the message.
It must be an AM IF receiver.
audioguru2
Apr 6, 2004
12,026
I forgot to say that this radio circuit is for narrow-band FM (telephone quality). My FM transmitter is for wideband high fidelity FM (broadcast quality).
A narrowband radio will receive wideband signals with extreme distortion.
Kevin.
Nearly all FM radios use a 10.7MHz IF amplifier. The FM sound received by TVs uses a 4.5MHz IF in North America, I think it is 5.5MHz in Europe.
10.7MHz, 4.5MHz (and 5.5MHz) and 455kHz ceramic filters and tuned transformers are used for the bandpass.
Learn about how radios work.
AN920
May 15, 2005
359
The RSSI (Received Signal Strength Indicator) is the output from a internal log detector
walid1
Jun 27, 2004
749
Hi guru
Hi Kevin
Guru, you are the king here, at least for me.
I’m already learned about radios.
I know u said that to escape from my 10,000 questions that will coming soon (smiling).
Look guru, I read about radios more than u expects. Theories do not suffice my requirements to be an expert like you.
During the discussions with u I got a valuable information that can’t get from hundreds of books.
So I need your help to fly together in the electronic world.
Lets start flying:
If I follow the connections in the phone’s board, I’m sure that I’ll find the remaining RF, mixer and the local oscillator.
I’ll draw the schematic by hand and scan it by a scanner and put it here for discussion.
When two signals entering a mixer, then the o/ps of the mixer are:
 The sum of the two
 The difference of them
 The same signal 1
 The same signal 2
So if sig 1 is the main i/p sig with freq = 10.7 MHz
And sig 2 from a local osc with freq = 10.245 MHz
Then one of the mixer’s o/p is the difference = 455 KHz so we use a ceramic band pass filter of 455KHz freq.
I write this to convince u that I have some basics of radios.
(1) What the difference between wide and narrow bands  in numbers? Please    don’t disappointed from this question.
(2) Can we modify your Tx to be a narrow band?
Thank u guru and all members of this great communty.
audioguru2
Apr 6, 2004
12,026
I don't know how narrow is the bandwidth of wireless telephones. It might be only 6kHz. Broadcast AM stations are only 10kHz apart so their bandwidth is about 8kHz.
Broadcast FM stations have a bandwith of 150kHz.
My transmitter doesn't have a limiter so if you are too loud into its mic its bandwidth exceeds 200kHz.
walid1
Jun 27, 2004
749
hi guru
Now we need a limiter
now i'll search about it
can you point me to make this mission easy
thanks
audioguru2
Apr 6, 2004
12,026
Hi Walid,
Our new Disco-light project has a limiter circuit "stolen" from Elliot Sound Products. I haven't tried it so I don't know its range and distortion:
walid1
Jun 27, 2004
749
Hi guru, thank u very much.
Please look at the figures below:
(1) If I introduce this limiter between the mic stage and the remaining stages of your FM Tx, then it will function as a AGC, that is it control the amplitude of my voice so that the o/p freq BW about 6KHz or so?
(2) My circuit board is SENAO SN-736, I think it have a transmitter circuit with freq different, if I can find it and modify its freq to match the 3359 receiver. I haven’t the second part of this phone.
audioguru2
Apr 6, 2004
12,026
Hi Walid,
Your transmitter and your radio circuit are very different:
1) The transmitter is wideband and the radio is narrowband. If something doesn't work properly then you don't have another narrowband station to test your radio with, and you don't have another radio to try the modified transmitter with.
2) the limiter circuit has a line-level input but the transmitter has a microphone and a mic level input.
3) The transmitter has pre-emphasis for good sound but it isn't used for narrowband.
walid1
Jun 27, 2004
749
For these reasons I suggest to find the Tx in the same board. I know it send to another receiver but we can modify its freq to match our receiver.
At this moment I lost my scanner (acer) software, I'll find one then I can send a photo of the board to get a help from u to find that Tx
guru I fond to FM circuit, I dream to build my own walkie talkie.
NOTE: during my search i found this page, it seems to be very important, i read it but can't understand what that modifications he did to get what?
http://www.discriminator.nl/ic/index.html
walid1
Jun 27, 2004
749
Hi guru
Finally and after some effort I can borrow a high rolsolution cam and take some photos, please look below
the first figure is for awhole SENAO SN-736 board for you to look
the second is a close view to 3359 Ic and related components.
I need your help and any help frome anyone here to enable me to take the suitable components to make a TX and Rx
To reach this target, we shall preview many important aspects.
i noticed that nearly all cordless phones have the same idea and same components with very small differences.
Where is the Tx circuit in the first figure.
Later I'll draw the shematic though it is double printed and hard to retrace but I'll do all my efforts.
thank you.
audioguru2
Apr 6, 2004
12,026
I don't know how you are going to design a narrowband dual conversion FM radio without a schematic. It needs a double-sided pcb with a ground plane over most of its surface.
walid1
Jun 27, 2004
749
Hi guru
dont worry I'll draw the schematic and discuss it with you.
I can do it, u  help me, we can do it.
now i'll draw the Rx (3359) and related parts and put it here, then u tell me where the TX part
I see the two LM567CN, i know they are for tone detection
I'll draw all pars in sequance and discuss them with you
guru I want to work hard and I need you help what u say???
yours Walid
walid1
Jun 27, 2004
749
Hi guru
As you know if u click on th followin image it will become bigger
http://www.electronics-lab.com/forum/index.php?action=dlattach;topic=9699.0;id=6451;image
can you please tell me where the TX to draw it
thank you
audioguru2
Apr 6, 2004
12,026
Hi Walid,
Is it a wireless home phone? I never looked inside one before and I have never seen a schematic of a narrowband dual conversion FM receiver circuit before. I am sorry I can't help you.
Look in its sevice manual.
