HELP: need to get away from 9v spdt relays!
Musicman1
Jun 23, 2017
Hello, I use 6 5pin 9vdc spdt relays to check connectivity for audio chords, using red/green leds, Im desperate to get into a ssr configuration if possible (smaller solid state of any kind for size)
What can replace this simple 5 pin relay? Is there anything simple? Thanks
duke37
Jan 9, 2011
5,364
You can get spdt relays in a TO5 can. If you give your circuit with power supply and load, I am sure someone can recommend a transistor circuit.
Musicman1
Jun 23, 2017
Thanks for the tip Duke, was unaware of a TO5 will check out!
