Help on picking a part to use
I have outputs from 4 A/D's. Each output is 8 bits ( // output ) and
will likely be sampled at 40MHz.
I need to manipulate that data in some kind of device. This includes
level shifting, multiplying the data against each other and possibly
applying some FIR filtering to the data. The output will be three 8
bit data streams running at the 40 MHz rate. Can anyone suggest a
part
to consider using for an application such as this?
Thanks.
Brent
Andrew Holme
part
An FPGA e.g. Xilinx Spartan-3.
linnix
Xilinx Spartan3 FPGA. No sweat at 40 MHz. Exactly which one depends on
how much math and buffering you need to do. Maybe you can quantify the
requirements a little better and post to comp.arch.fpga, where people
can suggest actual part numbers.
John
I would suggest a small high speed sram with it, since he is doing
FIR. It should cut down on the gate counts, unless cost is no
concern.
Depends on the size he needs. We're using an XC3S1500 in a couple of
products, and it has 64 kbytes of block ram. The block ram is very
fast and dual-ported, which is mighty handy, and you can partition it
all sorts of ways. It costs about $67. An XC3S200 is more like $10.
FIR needs a lot of multipliers. We usually wind up using IIR filters.
John- Hide quoted text -
- Show quoted text -
Thanks everyone for the useful inputs
linnix
I think you should go with the xc3sd3400a. It costs around the same
as the xc3s1500 ($70) but same number of MAC (104) as the xc3s5000
($120). As John said, you will likely be MAC bounded. For four
inputs, you can do 25 TAPS FIR.
linnix
How fast are those macs? With a multiplied 40 MHz clock, he could do
multiple mac operations per "adc" clock, three or four at least, so
effectively get more multipliers. In other words, run the filter math
faster than the ADC rate.
I believe they are single cycle MAC. Xilinx's are 18 bits and Altera
can be down to 9 bits. But a partial serial (4 TAPs per clock) design
would be far more complicated than either a parallel or serial design.
One of my guys is a fan of boxcar averagers, which take very little
resources and act sort of like lowpass filters. You can combine them
with other-length boxcars, or simple IIR lowpasses, to zap some of the
uglier sinc effects.
The xc3sd3400a is going in the right direction, with more MACs and
less gates. If only they can cut down the BGA pads (600+). I wish to
have a thousand MACs in a 64 pins TQFP, less than $5 of course.
linnix
16 bits in, 16 bits out, power, ground, clock. How about a DIP40?
John
Yes, 1.27mm pitch DIP40. I'll see if I can fit the 464 BGA in it.
Don't forget jtags as well.
JosephKK
concern.
I am not so sure about that if you have to off chip and back on, that
takes a lot of cells also.
linnix
Yes, simple sram wouldn't do it. We need multi-port register cells.
But even with the top end chip, we are MAC bounded (100 to 200). So,
the OP might end up with multi-chips with external registers anyway.
We really need more info about his spec before making educated
guesses. For example, are the transfer functions linearly independent
on inputs? What is the order of the FIR filter?
The good news is that Spartan 3a dsp chips are surprisingly
affordable. I though they were thousands of dollars before. Even a 5
chips solution (4 inputs + 1 mixer) would not be too expensive for a
45MHz dsp problem. We also need to know his budget limits, of course.
