HELP - Please Identify These Two Parts....................
  • Thread starter Reinhard Zwirner
  • Start date
Eeyore
Jamie said:
that diode is suppose to go across the motor leads to suppress back
EMF which can damage components..
It would be a simply low current SI diode.
In which case putting in something bigger like a 1N400x ot UF400x if it has
to be a fast device would do no harm.
I've known 'back emf diodes' like the 1N4148 to be 'killed' by even modest
size relays. I never 'cut corners' on that component any more. 1N400x every
time.
Graham
Eeyore
EADGBE said:
The anode of the diode is attached directly to three of the resistors
as shown.
I have tried to re-create the circuit board traces on the other side.
The cathode connects to what N_Cook has described as an inductor.
Take a look at this photo:
http://i240.photobucket.com/albums/ff58/eadgbe123/DIODE.jpg
Thanks to everyone for your help so far.
Can you not trace out the whole circuit ? There's precious little there.
Graham
Eeyore
EADGBE said:
Actually, I'll do just a bit better.
Here are ALL of the circuit board traces, done as best as I can. Let
me know if the traces aren't clear enough:
http://i240.photobucket.com/albums/ff58/eadgbe123/CIRCUIT.jpg
By the way, the AN6601 laid flat against the circuit board, with the
label side DOWN.
Oh, go on, draw a schematic !
BTW, that black electrolytic may well have had a good cooking. I'd
replace that too.
Graham
EADGBE
Well, it has all become academic at this point.
I ran the motor off of a 9v battery while it was hooked up to my
multimeter's current setting.
The motor was pulling just over ONE AMP of current!
I took apart the casing and studied everything....sure enough, one of
the armature windings has a scorched spot.
This motor has gone to that Great Cassette Deck in the Sky....
Richard Crowley
You could have re-wound the motor! :)
Mark D. Zacharias
Yeah, I know...but I'm just too lazy! :)
There are replacement motors available from MCM and the like...
12V CCW, 12VCW, etc.
Standard mounting holes.
Usually pretty easy to wire in place of the original.
Mark Z.
