Sorry for such a newbie question but I don’t want to make an incorrect purchase. I am replacing the capacitors in two monitors. After searching through Digikey I found I had more than a few choices. The first monitor has radial can type capacitors 470µf 25v and 820µf 25v about 20mm in height. The second has radial can – SMD type 10µf 50v (?) about 6.5mm x 6.5mm surface diameter and about 6mm height and 100µf 25v(?) about 8mm x 8mm surface diameter and about 8mm height (I will have to pull them to get a more accurate measurement). I am looking for the best brand and quality, any help in getting the right capacitors would be greatly appreciated
Thanks in advance, Jay
