Help : PWM generation
Hirak
Oct 17, 2020
Hi ,
I want to generate voltage control PWM signal(0-5V) duty cycle vary from 10% to 90% and at the same time i want to change frequency with changing voltage whenever is required.
please help me to design that.
Thanking you,
Pratik
Alec_t
Jul 7, 2015
3,821
Welcome to EP!
This circuit may meet your needs. Duty cycle is voltage-controlled but the frequency is controlled with a variable resistor.
Hirak
Oct 17, 2020
hi,
i am using the circuit in HV application. can i used that circuit?
hi,
The IC inverter used is around 5v (6V max) so that's pretty much the limit.
No idea what you mean "use in a hv circuit".
Possible to interface with an opto of some description.
Best show the circuit.
Alec_t
Jul 7, 2015
3,821
Agreed. Post your intended HV circuit, including voltage, frequency and current particulars.
