HELP-Sony KV-27TS29 went dead
Jerry
KV-27TS29 just clicked off and won't power on. Can anyone advise me
on what to look for as the cause? I'm fairly competent when pointed in
the right direction. Thanks.
...and it happened right in the middle of our first viewing of the
Matrix Reloaded! What a way to ruin a Saturday night. I could cry...
David
Power supply problem, horizontal output stage problem, system control
problem, plus a few others come to mind and could cause your symptom as
described. Need a little basic troubleshooting information to give anything
more than a guess.
Those series of Sony sets are known for problems in many different areas.
Plus you will need to order the parts once you are sure what needs replaced.
David
Jerry
Thanks. HI thought it might be an easy and or common problem.
A little more info: There seemed to be a grey line on the right edge
of the screen and it kind of bent toward the center of the screen a
coupole of times early in the movie. I figured it might be the DVD.
When it went out, it sounded just as if I had hit the power button.
Any basic tests I can run on the power supply to see if it's the
culprit?
Jerry
Thanks. I thought it might be an easy and or common problem.
culprit?
David
You still need to perform some basic tests inside the tv set for any better
information.
If you do a Google groups search for any or all of the following;
Sony tv, dead Sony, 27ts29 or similar model number, etc
You will probably find lots of hits for similar problems that should clue
you in.
Pay close attention to ones regarding SMPS problems with Q601,Q602,R627,
HOT, etc.
The Sony SMPS in that tv is NOT one to blindly replace parts and hope it
will run right again. A full series of proper checks really should be
performed to know that it is repaired correctly, otherwise the expensive
SMPS transistors will blow again.
David
