Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
Akuanka
Nov 23, 2024
5
Hi everyone,
I’m troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn’t power up completely. I’ve already replaced five capacitors, but the problem persists.
Here’s a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78 showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
Thanks in advance for your help!
bertus
3,877
The ticking sound may occur due to an overload on the powersupply.
There shoud be someting drawing to much current.
Take a look at the main board and see if there are some tantalium capacitors broken.
Bertus
Akuanka
Nov 23, 2024
5
Bertus
Hi Bertus, thanks for your answer. I have already replaced all electrolytic capacitor and checked good ones. there was no issue with that. How to identify the tantalium caps? Can I check them directly on the board?
Akuanka
Nov 23, 2024
5
Thanks again. Yes, I figured out that but was unable to understand their rating. can I check them directly on the PCB? I have a multimeter in resistance mode and checked with 20k and Million Ohms. They all show OL. Should I solder each one by one? there are also minimal markings that are impossible to read.
bertus
3,877
I am not talking about the powersupply itself.
It is likely connected to a board.
There is likely someting wrong with that board.
Something is drawing to much current causing the powersupply to go into protection.
That is the ticking you hear.
Bertus
Akuanka
Nov 23, 2024
5
Hi, Yes, that is clear but how to find which element is faulty this is the problem for me. I have already replaced all aluminium capacitors. Thos tantalum seem to be little tricky to test. Any ideas how to do it? Or could it be diodes?
Remove or at least, lift one leg of the cap.
With electros, make sure they are discharged first. A 10r 5 w resistor will suffice. For testing, buy a $30 component tester, best purchase you will ever make for the price.
Use a series lap tester to avoid blowing fuses.
player2move
Dec 1, 2024
4
I only remember issues with caps, when pulsing often the 2 small ones in primary part of psu.
Did you check the diodes for DC on secondary side for shortage?
And did you try to warm the psu with a hairdryer? Caps get back part of capacity when you heat them up.
As far as I can remember there are far more then 5 caps in your psu. If you want to keep the machine longer, i suggest to renew them all.
