HELP - Sounder Watts
Guest
Good day all
One newbie here needs a bit of help regarding sounder
wattage. All other variables being equal, how much
advantage is a 1KW (Tru The Hull) sounder over a similar
500 watt model?
A second question is how much will a fairing block
improve the display? The assumption is it will provide a
more stable picture at higher speeds. I boat in Alaska
where 1000 foot depths can occur as little as three
quarters of a mile from shore. Thanks - Cap'n Phil
Bruce in alaska
Good day all
500 watt model?
One other thing to note here is, Frequency has far more effect
on Maximum Sounding Depth than Output Peak Pulse Power. If
your looking at only the top 100 ft, for fishing, then 200 Khz
is what you want, and you don't need more than 100 Watts PPP.
If your looking for the bottom and it is over 200 Fathoms, then
50 Khz is for you and 200-500 watts PPP, will certainly help.
If you down past 300 Fathoms, and your looking for those elusive
King Crab, the 28 Khz and 1-2K Watts, is going to be your friend.
Another note here, as well, Resolution is the Inverse of Frequency.
If your looking for fish, and want to see individual fish, like those
elusive Spring King Salmon, then 200 Khz is your friend. Otherwise,
your not going to see individual fish, with a 50 Khz or 28 Khz machine.
Bruce in alaska
Capt John said:
The higher output transducer will help with readings in deeper water,
getting better readings when you have a thermocline, and soft bottoms
in deeper water. Now if your operating the boat in say 300 or 400 feet
of water (or more), and want to get a real clear picture of the bottom
for bottom fishing, the higher output is better. But if your operating
in shallow water most of the time, or on the occasion where you do run
to deeper water you really don't care if the bottom picture is
perfect, save your money, you don't need the higher priced unit or
transducer.
A Transducer has a Maximum Power Limit but does NOT have a higher "power
output", in, and of itself. The Power Output is determined by the Final
Transmitter Stage Design, not the Transducer size, or design.
