Help to choose the right ADC
I'm new about adc, so i need help to choose the right ADC....
i have this signal:
1)signal bandwidth=0-4KHz ==>8ksps min
2)noise free resolution=14bit
other parameters:
1)number of channels:1
2)Vdd=3.3V (preferably)
I'm oriented on sigma-delta adc, but i haven't found adc with this
parameters...Also a sar adc coud be a good choice, but in this case a
greater sps is necessary (i think) to obtain a simple antialiasing
filter....can you help me?
Thanks in advance
Rich Webb
i have this signal:
other parameters:
To avoid aliasing into your 14-th bit, you'll need a higher sample rate
in addition to a front-end antialiasing filter.
On the filter side, first, your simplest approach may be one of the
switched capacitor filters from Maxim, Linear, or TI. The corner
frequency can be tuned with an external capacitor or external clock (for
a more stable response).
<http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=MAX7414EUA+-ND>
is one possibility among many. Some are available in DIP, if that's
easier to use. Other options, of course, including roll yer own.
On the sample rate side, a 5-th order filter would require you to sample
at about 60 Ksps in order to put Nyquist about 84 dB down and prevent
higher frequency signals from being aliased back into the passband at an
amplitude that will show up in the 14-th bit.
Thanks for infos,
but i have a new question:how to simulate it?With your help, i've
chosen an sar adc from linear technology....but i don't kow know to
simulate it (if possible) with spice. I've downloaded from website
pspice library, but i haven't found any adc (perhaps i'm
wrong)....i've downloaded ltspice, but nothing i've found...It's the
first time that i use an adc, so can you help me?
