Help to find Sata To 4Pin power connector cable??
Cyber Tech
Nov 23, 2016
4
Anybody can help me to find the cable which connects SATA to 4 Pin Power on DVR.
Please see the attached pictures. What's the name of white 4 Pin Connector? and from where I can find this cable or at least white connector alone so I can make it myself.
One side of this cable has SATA Connector which connects to Hard drive and other side has 4 pin connector and it's 15.5mm wide.
This cable is used in most of the DVRs to connect Sata hard drive.
Thanks in advance.
Cyber Tech
Nov 23, 2016
4
Yes I tried but couldn't found this 4 pin connector. There are many 4 pin Molex connectors which connects to IDE hard drive. But this is 4 pin connector which is 15.5mm wide and each pin is 2.5mm spacing.
Cyber Tech
Nov 23, 2016
4
Thanks for the reply. All the results came for Molex IDE connectors not the connector I am showing in pictures.
This cable is used to connect Hard drive power to DVR board.
Cyber Tech
Nov 23, 2016
4
The Floppy connector is small. I am checking Alibaba to see if somebody sells that.
Yeah, replace "hard" with "floppy" in that google search :).
Id try the same search on eBay.
