Help wanted on a CMFB problem.
gfang
Hi everyone,
We have a unity gain fully differential buffer with continuous time
CMFB in our design (0.18um CMOS). This buffer's output common mode
voltage always saturates to very close to positive power supply as soon
as it's turned on. In simulation, we had to add greater than 10%
mismatch to induce similar result which is highly unlikely in practice.
The circuit uses a two stage folded cascode as the first stage and
a CS stage as the output stage. The first stage has two differential
pairs to handle the possitive and negative input and the unity gain
feed back. A third differential pair is used to handle common mode
feedback. One of the branches of the common mode differential pair is
split in two and merged with signal path differential pairs to form a
current stearing CMFB. The common mode detector is just two resistors.
We'd appreciate it very much if someone could point us to the right
direction for finding the root cause of this problem.
Thanks in advance for your help.
George
Jim Thompson
Hi everyone,
George
You need to post a schematic on alt.binaries.schematics.electronic or
a link to your URL.
A simple-minded question: What is the reference voltage for the CMFB?
...Jim Thompson
