Help with a wiring circuit
Porkncheese
Nov 14, 2015
Hi guys. I have a seadoo jetski and the VTS (variable trim system) doesn't work.
The part I need is the VTS module. A magical little black box that seadoo want $250 for.
I think I know how to wire this up but being a novice with electrics I would like to get confirmation and the opinion of people who know.
Here are the components of my system.
The switch with a button for up and another for down. 3 wires go to this.
The motor has 2 wires to it. It remains stationary unless one of the buttons is pressed. Up will turn it one way and down will turn it the other.
The motor pushes or pulls a rod which is is fixed to the nozzle of the jet pump. It directs the thrust up or down which changes the ride of the craft.
2x relays. 12V DPDT 10A 8 pin
This is what me and a friend came up with.
Neither of us work in the industry so i think we may have it wrong.
Or maybe there is a far simpler way.
Any words of wisdom would be kindly appreciated.
Martaine2005
May 12, 2015
5,318
Sorry, that diagram is confusing..
The up and down buttons are only for motor direction.
Two simple circuits using relays for the motor, one relay connects the motor wires for "forward" and the other relay with reversed wire connections to "reverse" the motor using the two switches by the hand grip.
You can confirm this by connecting the motor to a battery. The motor will turn in one direction. Then reverse the connections on the battery and the motor will turn the other direction.
All you need to do is see what direction the motor turns in order to push / pull the rod correctly.
Then you know to use the up button or down button for correct direction.
Look for the pinout or datasheet for your relays. It should even have a wiring diagram too.
Martin
Diagram makes sense to me.......(I think you did quite well considering)
one button operates one relay which supplies "forward" direction...
the second button operates the second relay which gives "reverse " connection to the motor.
Only problem I can see is there are no limits and no fuses.
These guys seem to have a fix but you will have to join their forum to see the pics and the pdf files....(I wasn't prepared to but you might)........ http://www.pwctoday.com/showthread.php?t=295371
Martaine2005
May 12, 2015
5,318
Something like this should work. Just omit the limit switches if you don't need them.
index.php
CDRIVE
May 8, 2012
4,960
It's moments like this that scares the hell out of me because I don't know what I'm looking at in that pseudo schematic. What ever you're drinking or smoking, I want some! :D
Chris
CDRIVE
May 8, 2012
4,960
Hey, if it can transform that into a schematic for me I'm game! :)
On the other hand I've never been a big fan of ASCII schematics either! :confused: Maybe that stuff can fix that too? :cool:
Chris
Porkncheese
Nov 14, 2015
Thanks guys. Our designed worked perfectly.
Im not running limiters. The fuse i just didnt draw it
