I just bought a used air hockey with a overhead scoreboard. The problem is both goals sometimes counts on their own, if you disconnect both goals then neither counts. I tried adjusting the sensors but eventually they will count. I think the problem is with the controller because after about forty seconds the scoreboards will flicker and it seems to really happen after the flicker. I have some background in electronics but havent dealt with it on the board level in about twenty two years. Where should I look, would it help if I up loaded the board? thanks
