Help with Atari Rush the Rock Schematics needed
Bob T
I have two of these I'm fixing fro a friend and both have motor driver board
issues
I need schematics for a Atari 055315 driver board or would appreciate any
thoughts on where to get one
thanks in advance
Meat Plow
issues
thanks in advance
www.google.com, use "atari schematic" for keywords.
What the heck is Rush the Rocket?
James Sweet
board issues
thanks in advance
What sort of issues do the motor driver boards have? Are they complex?
Usually that sort of thing is pretty easy to diagnose without a schematic.
James Sweet
Meat Plow said:
How about scanning Google Groups for articles related to Atari Arcade
Games? Maybe there is another news group where repair of those things are
discussed?
There is rec.games.video.arcade.collecting, but I think most of the techie
types who post on there are on this group too.
Bob T
There are two boards each with different symptoms
#1 has the drive such that the wheel pulled hard left
I suspect a blown op amp opa541
the second jumps around when nothing should be happening intermittent
I swapped the boards between machines and the problems followed. No obvious
memory parts on the boards to I think I have some analog or drive problems
These machines were both bought recently and haven't worked since they were
delivered so I suspected the usual broken or hairline cracks on electrolytic
caps but found nothing
James Sweet
obvious memory parts on the boards to I think I have some analog or drive
problems
were delivered so I suspected the usual broken or hairline cracks on
electrolytic caps but found nothing
Start by checking the output devices, a shorted transistor in an H bridge
will cause the motor to pull hard one direction. If you suspect an op-amp is
bad, replace it, they're cheap, you can always desolder specific pins to
isolate sections of the circuit and work your way back.
The jumping around randomly can be a lot harder to track down. Are you sure
no decoupling capacitors got knocked off? Those can cause all sorts of
gremlins.
